SOURCE: iTunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
SOURCE: Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
SOURCE: Where can I download a driver for my plantronics
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Testimonial: "I did that before contacting you and they state Windows driver is compatible but Vista asks for driver. Headset older"
