I am using asus p5sd2-vm with p4..while playing games its hanging
I am sorry, but I am not a gaming fan and it just never happened to have that much of an interest. Finaly someone gave me a computer that has a MB with special provisions for gaming. I noticed that one can change the BIOS specs without having to open the device and take half a day to set it up. If you can wait a while to do some research and can stay with the lower speed of the games. I just thought of something! When you acquired the ASUS MB and you installed it in your unit; there are two things that can slow you down: one is the size of your RAM memories and the other is their speed. Unfortunately if you change their speed, you will need to change all the memories because they are paired or triplette, because if one is super fast and the other just fast, you can burn some of the RAM memories I can see of an easy way to check it out: you probably have two memories, unless you added one more. Modern computers have only two slots, because it is no longer needed to have more than two. In either case, after you make sure you will not blow them up due to your static electricity, then we can proceed. The static elecricity can zap a memory just if you are charged... Please, before you touch anything you discharge yourself by tounchin on a piece of ground (the computer frame for instance. Another way can be prefered because you will have free hands in this way. You buy a cheap bracelet put it on your most comfortable wrist, attach a wire from the bracelet to your ground and this way you will always be grounded, but your hand will be free. So, once you are grounded, with the computer disconnected by the AC plug you remove one of the memories #1 would be a good choice. Turn it one and observe the spped of the game, then change #1 with #2 (and #3 if there is one). Asuming that you have only two memories, you take out one and then you place #1 into #2 slot. If you have three slots, you just do excange the position #1 to #3, #2 to #1 and number 3 to #1. After each changing you will need to turn on the computer and check the speed. If you want to be much better yet, you check with instruction manual on the frequency of the RAM memories. This time you will have to buy some that can be paired or tripletted, other wise they will not work. There are also 2GB DDR memories available now that you can double or triple your RAM memory. The RAM memories are repositories, where the computer, after a calculation, will place the result, until it needs it again. Another advantage of the RAMs is that they have no moving parts. The trick is that the RAM memories should have anough capacity to be able to take an entire program, whenthe computer will never need to activate the HDD. Let me know if my comments have help you any. First, we are graded by your comments. The other is that I have been a computer design engineer for 33 years and I have seen just about all the fallpits and adversities. Believe me I am old enough and I want to pass my knowledge to you younger guys... So, please let me know what happened. We thank you very much for considering our service... Let us hear from you...
My name is Constantin (arzconst is my nickname with Fixya.com)
gta sandryas and cricket 2007/8 game is very slow on my sis672 hcl b3012 laptop
i have 4 gb ram core 2 duo processer with 256 mb shared memory.
poor graphics showing
pls send the solution on my mail id [email protected]
Specs:- Asus P5 - SD2
2GM DDR2 RAM
Intel Core 2 .2
Ffia 09 works very poorly, so does NFS UG2....
My motherboard however shows Asus P5-sd2 DM when I start the machine....would try the updated and let u know...!!!
poor graphic during games
