SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays
"E3" error code
Check data cable integrity All wires in cable should be intact. If any
are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
SOURCE: my schwinn 240 recumbent bike shows E-3 on
Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
SOURCE: schwinn 220P no resistance
see this steps and fix it. God bless you Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance. Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced. Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine. Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break. Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
