Won't start means that the cpu fan spins, the hard disk runs but no signal to screen or any activity at all. When the old P4 is inserted it's all good again. Even disconnected mobo battery, power connector and reset cmos, nothing makes any difference. !! Thanks
SOURCE: cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
SOURCE: no video after power up biostar t series MOBO w/ Semprem cpu
i was installed xp sp2 but vga driver & multimidia driver not installed
SOURCE: black screen on boot on biostar mcp6p m2+
That board has a built in video card if I have the right info. If you are using an external video ie plug in card then you need to make sure the onboard video is disabled or that the plug in card is designated as the main video card. Not doing either of those will cause the black screen.
SOURCE: motherboard biostar p4m890 m7 can'toverclock intel dual core 2140
Because this is a very basic motherboard, with a very simple chipset without extra capabilities, let alone performance ones like overclocking.
