Replace front speakers
You would have to open the door panel to replace front speakers. Look for any screws around the door handle. look at the whole door panel for any screws so that you may remove the panel in order to reach the speakers. once the panel is free from any visible screws, use a door panel remover ($5-10) and use it to pry off the panel, use it around the door panel push-in connectors, and don't use extreme force, may break connectors. once the connectors around the whole panel are removed. make sure your window is down before the whole procedure. then pick up the panel from the bottom (push up), then the panel should be off the door, if you want to change the speakers, you don't need to take any of the wiring to the window/door lock. simply remove the cover if any over the stock speakers, usually some screws. once the cover/screws are off. the speaker should come off. You will see two wires off the speakers (the red(positive) the black(negative)), once the stock speaker is removed, simply attatch the new speaker to the wires. make sure the negative and positive from the car DO NOT TOUCH, you WILL short circuit and blow a fuse, maybe worse, and it's not worth the time fixing. hope this helps, good luck.
