SOURCE: Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
SOURCE: roland xp 50. everything works find except sound
Yes, he is full of it. For parts try Digikey.com, Mouser.com, and AntiqueElectronicSupply.
SOURCE: My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
SOURCE: my Roland d-50 keyboard ic
There are lots of IC's in the unit. Order from Roland support parts. That will be the only source.
