The splined Poulan Carb Adjustment Tool, 530035560, which was readily available for less than $20.00 before 2013, has become scarce and bottom the feeders are price gouging. Check ecrater.com and curtschainsawparts.com. I just received one and it is the quality item at very reasonable price, $14.00
The tool required is part no. 530035560 it fits onto the splined jet screws. Check the web for prices etc.
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
SOURCE: What tool is needed to
This machine has a carb with splined adjuster screws, the toll to adjust them is part no. 530035560, it is readily available however i heard that the dealers in the US are very reluctant to sell it to end useres, so you may have to buy off the web.
