Recently, I purchased 2008 Acura TL Type S. Love the car, but after having it for two months, the navigation system went blank. The screen turned solid black. I cannot get it to come back on. Then, this morning, it came on for about thirty minutes and then turned black again. How can I fix this?
I have a 2007 Acura TL. The navigation system worked well, until 2017, when I decided not to renew it. Everything started to go wrong. It worked intermittently. Cost me job interviews, getting lost and being late. Did you receive a message, "See your dealership"? Well, the dealership was charging the same as the renewal price. A coincidence or an attempt to force the renewal? Well, I gave in. I just received the new navigation system (disc). It hasn't been installed as yet. Try reprogramming and find out how old the system is. A great car. The turning radius and the navigation system are my problems. Good luck.
SOURCE: 2003 Acura TL TypeS - heat and air not working
it's a wire from under the dash it usually burns out after awhile,i had the same problem email me at [email protected] for more info on the wire i forgot the name for it.
SOURCE: Navigation Code
True. It is in the trunk under the plastic carpet. You need to remove the bolts from the navi dvd and flip it over. Write down the serial number and go back to the dealer. Show registration of car and have car with you. On 2005 and up cars with navi the tech can go to a secret tech screen and get the serial number.
SOURCE: Acura tl 2008 CODE ERRORE
radio is locked out from installing incorrect code to many times need to disconnect battery for couple minutes then reconnect and install correct code
SOURCE: my Acura 2003 TL 3.2 stop working all both system
it is probably the blower motor resistor, had the same problem on 2003 CL Type s, the fans for the A/C and heat just stopped working was the symptom . The part is only about 70 dollars.
