Sony CDX-M630 CD Player Logo
Upset person Posted on Feb 26, 2013
Sony cdx-gt610ui buttons won't work
Nothing works. The deck will play music if you eject then insert the cd, but I can't change the volume nor use any of the functions. I tried the reset button but nothing seems to work..
Marco Hernandez
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 06, 2013
Marco Hernandez
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
836
Points
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Oct 29, 2006
SOURCE: tuner does not work Sony CDX-L420V CD suddenly.
Try cleaning the connections on the faceplate and were the faceplate meets the unit, Make sure you disconnect the power first (pull the fuses) look carfully at the pins on the radio itself were the faceplate and the radio meet see if any are bent or out of place. I think what the other person was talking about fuses is there is two fuses on the radio and there will also be two fuses in the car. So there should be four fuses to check depending on your car. Good Look.
A
Anonymous
  • Posted on May 25, 2008
SOURCE: Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. [email protected]
Anonymous
  • 10594 Answers
  • Posted on Oct 02, 2008
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Anonymous
  • Posted on Oct 04, 2008
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Anonymous
  • 3 Answers
  • Posted on Mar 13, 2009
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Guys, I have a CDX GT610, the issue is that is
hi marco, the problem seems with the switches on the face. make sure that ALL switches have a "click" sound when pressed down. if not then that switch needs to be replaced. faulty switches can cause the face functions to work erratically. to try another route use your unit with the wireless remote control to check if all functions work well. cheers.
1helpful
Hello, I have a CDX-GT610UI Song Car stereo. I was just wanted to know when using the USB slot to play music what controls the order of the music? Thanks, Jason
For future reference, the manual can be found at this link
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT610UI
On page 10 of the manual, the controls for mass storage device playback are as follows:
3 (REP)
4 (SHUF)
Press 3 or 4 repeatebly until the proper selection is displayed.
You can select Repeat Track or Album with 3.
You can select Shuffle Album or Device with 4.
To turn off the repeat or shuffle, click the appropriate button (3) or (4) until Off appears then the songs are played in the order they are found on the device.
Sony cdx r3300 Won't play...simply scrolls a message
2answers
How do ya work this thing?
Press the SOURCE button "Bottom left of Row"
NO DISPLAY NO SOUND
ok check for good earth and also check you 12v constant 12 acc... aslong as you have all three it will work...
2helpful
2answers
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Buttons don't work but still plays cd
deattche the front panel and reattche it ;) hope it will work fine up to next year. :D
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
