Hello, I tred to install a SATA HDD on this motherboard, but it is not seen at all. I went into the bios, the SATA is enabled. Are there some jumpers that need to be set on the MB? Thank you!
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
SOURCE: SATA II HDD instaling on ASUS P5LD2
Drivers will not affect whether the drive shows up in BIOS or not.
Your BIOS should have a setting under the 'Advanced' section for IDE and or SATA. Usually this needs to be set to 'Enhanced' mode or 'SATA plus PATA' Check your jumper settings-The drive should be set to 'Master' (if it even has jumpers).Check the power lead to make sure the drive spins up. Try different power lead and different SATA cable. If possible, try the drive in another machine to make sure it isn't 'Bad out of the Box'
If the drive does not show up in BIOS its a hardware issue or BIOS setting .
Once it shows up in BIOS - you'll be good to go.
SOURCE: SATA drive not seen.
Hello.
Below is a link to download the instruction manual for free. This will give you the settings you require.
http://www.ziddu.com/download/15162268/ManualforKM4M-V.pdf.html
I hope this solves your issue
Regards
GM
SOURCE: I have a MSI V
this this site http://www.msi.com/product/mb/PM8M-V.html#?div=BIOS and upgrade your BIOS it may help.
I use XP. I tried to connect the SATA alone (does not start up), and then together with the IDE (it started, but it did not see the SATA)
