I call my satellite company and they were not able to solve the problem. They had me try moving my inputs around and different HDMI cables, but nothing worked :( please help!
SOURCE: vertical lines in picture
If your satellite is in the component jack and does not have the lines, you have a bad doubler or 2HD board. These boards are located in the metal container on the left side of the tv (left as in when you are looking at the back of the tv).
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
SOURCE: wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
