Try one of these and if the first one does not work, use the second, and if that even doesnt work maybe the third, if that doesnt work send me an email at [email protected] and i will give you more
For Half life, try one of these:
1374-65331-7652
3875-64086-6284
4080-85820-9135
For Blue Shift, one of these:
2884-52653-7164
1911-23143-1234
Counter strike, one of these:
4422-93598-8995
8474-05768-1841
8495-78586-5785
and opposing force one of these:
GAS9-DAB2-PUR3-BAP7-6587
XYN5-SAB2-NEL2-PUW3-2585
SOURCE: Counter Strike:Condition Zero
go into the game its self then there will be a lan button or newserver click that start a new server it will give you and ip then your brother can go in to consel (~ button) and type conect(enter the ip)
SOURCE: counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
SOURCE: cd key for counter strike 1.6
download it from here: http://rapidshare.com/files/69342895/Cs_Keygen.exe
SOURCE: help me down load the game counter strike
If you want to download counter strike 1st thing you do is go to google.com then type utorrent then download and installed it after you install go to www.kickasstorrents.com then search counter strike.. Then download it then its done just wait ti finished it then install.. Happy gaming.. I hope it will helps you
