Volume buttons when pushed continously won't display on the screen volume change, volume increase and volume decrease and eject key on the keyboard shortly before I installed windows 7 Ulimate upgraded from windows vista. I first noticed it after I uninstalled VAIO Original Function Setting version 1.4.00.04230, VAIO Event Service version 4.1.00.07150, Intel(R) PROSet/Wireless WiFi software version 12.04.3000 and McAfee SecurityCentre in that order. Please advise how to solve this problem.
Http://www.sony.com.au/support/product/VGN-AW15G near the bottom of page you will find your missing drivers and the instructions for installing them
SOURCE: VAIO VGN-AR630E Drivers for Vista Ultimate
try going to the official site of vista and see if it can help lol or just reverse the process lol
SOURCE: i need driver for sony vaio vgn-cs215j PC Notebook
You can go to this website:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCS215JP&SelectOS=42
Select the operating system as Windows 7 and the updated cam driver is there..
Testimonial: "camara finally worked ,.. tanks... is there any software that would make the capture button work again? ... "
SOURCE: I installed windows 7 and now my function keys don't work
You need to install the drivers, windows does not recognize these additional buttons until the proper drivers are loaded. Depending on manufacturer windows 7 drivers may or may not be available. Microsoft did something smart with windows 7 by allowing you to use windows vista drivers in windows 7. So if there are no win 7 drivers just download and install the vista drivers. Good luck!
SOURCE: Sony Vaio VGN-AR71J Windows 7 upgrade issue
For install fresh copy of windows 7 you need to buy windows 7 disk if you haven't win7 disk.
Then insert windows 7 disk into computer then when you power up the computer press F1 or F2 or del or ALT + F2 key to enter in bios then go to boot emnu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with windows 7 disk then follow the procedure and choose install new windows option.
Then it take 30 to 45 minutes for completing the installation .
Then install driver for windowsd 7 from below link.
Click here
Click on above link then select your model and then windows 7 download all drivers and install then it will work fine.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
