SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
SOURCE: Nailer only will fire one nail at a time and will
I found your post a couple times, when you remove the nails does the piston/driver slowly come down? Also do you hear any air leaking around the cap? When was the last time you had it serviced. It sounds like the o rings are dried out or worn flat and possibly a seal on top of the cylinder might be damaged. Not to worry though, it is rather inexpensive to repair all that yourself if you are handy with tools. Let me know and I will find a breakdown for you before you attempt anything
SOURCE: Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
SOURCE: I have a Bostitch RN46 roofing nailer that has
SOUNDS LIKE YOU MAY HAVE RIPED THE DIAFRAM THAT CONTOL THE PLUNGER MOST OF THE TIME I REMOVE IT IF BAD I REPLACE IT
