There are two versions of your motherboard listed under the MS-6758 model. I've posted links for the sound driver for both models. Try and download and install the driver from the first before trying the second link.
Hi
Check this Link ..click on "Click here to start download.."
Save the Ms-8188 sound driver zip somewhere you can remember .(Windows XP compatible)
Double click it ,to launch the installation process double click on setup .
MSI MS-6758 Motherboard Sound Driver Download<--click .
Instructions to install the sound driver.
After successfully downloading the driver,open the downloade file.
When it's successfully installed , please restart your computer.
Today I installed VueScan on my Win7 (7264) X64. After that the 1250 was still not recognized. Go to start and execute/run devmgmt.msc. You will get the hardware list with a yellow marker on your scanner driver. Double klick on that icon. Now you need to go to the second tab (driver program if I translate it) and second button (renew if I translate it) where you can install drivers for the device. Tell windows to search on your computer and point to the VueScan directory (directly on C: , not in programs). Now Windows 7 (7264) X64 will find the driver and your Epson 1250 is recognized. :-) Tested and working.
This same method worked for installing the AlexP drivers for my PS3 Eyetoy on windows 7 (7264). Tested and working also.
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
wish you best of luck
Brian
