SOURCE: Model - HP Laserjet P2055dn. Issue - 49 Err
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
If your printer is getting a 49.xxxxx error after powering on, it has major problems, and a repair shop visit is in order.
The error in itself is a "critical firmware error"
SOURCE: i got and error message on my printer hp p2055dn
You probably are printing with a newer version of adobe and have not upgraded the firmware on the printer. Go here and download the firmware update utility, first option for upgrades on the page. Once downloaded run this utility and it will ensure that your firmware is up to date. If you cannot get the printer to come to ready, you will need to clear any print jobs that are in the queue waiting to print first.
SOURCE: I have PH Laserjet P2055 printer 49 err 4810E9E
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
