Computers & Internet Logo
A
Anonymous Posted on Feb 25, 2013
Samsung Syncmaster 733NW Monitor automatically shut itself in a few minutes
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Apr 24, 2009
SOURCE: Samsung syncmaster 794 mg CRT monitor driver.
download your monitor driver
http://www.samsung.com/us/support/download/supportDown.do?group=&type=monitors&subtype=crt_conventional&model_nm=793MG&dType=D&mType=UM&vType=R&prd_ia_cd=05020300&acc_ia_fl=&disp_nm=793MG&menu=download
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Jul 25, 2009
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Mar 30, 2010
SOURCE: LCD Samsung Syncmaster 740n 17... Fuse F301 is brocken.
You still have shorted out components on the circuit board, you will need to download tha service manul here to do an indepth troubleshooting: http://elektrotanya.com/
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on May 18, 2010
SOURCE: SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Anonymous
  • 10406 Answers
  • Posted on Nov 21, 2010
SOURCE: Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
I have Samsung syncmaster 733NW monitor. Dull display comes and goes sudennly when power ON.Blue light is glowing continuous. how to rectify
The issue you're describing with your Samsung SyncMaster 733NW monitor could be caused by a few different things. Some possible causes include a problem with the monitor's backlight or inverter, a malfunctioning video cable, or a software issue.
Here are a few steps you can try to troubleshoot the problem:
  1. Check the video cable: Make sure the video cable connecting the monitor to your computer is securely plugged in on both ends. If the cable is loose, the monitor's display may be affected.
  2. Check the power cable: Make sure the power cable is securely plugged into the monitor and the outlet. Try a different outlet or power cable to rule out any issues with the power supply.
  3. Check the monitor's settings: Make sure the monitor's brightness and contrast settings are set correctly. You may also try adjusting the resolution or refresh rate to see if that improves the display.
  4. Try a different monitor: If you have another monitor available, try connecting it to your computer to see if the problem is with the monitor or the computer.
  5. If none of the above steps resolve the issue, it may be a hardware issue. It could be a problem with the backlight or inverter, which would require repair by a professional. It could also be a problem with the monitor's main board.
If none of the above steps helps, it would be better to contact the manufacturer or a authorized service center to repair it.
Samsung SyncMaster 2333hd monitor shuts on and off repeatedly or turns off
I had a similar problem with my monitor, it turned out to be a loose connection inside the unit, there is a motherboard inside the monitor, it was between this and the LCD that a cable had come loose, some dismantling of the monitor but worth a try.
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
Syncmaster 181T periodically shuts down
monitor ACER 17" S/N #ETL460C148710572-B4045 just off for minutes at a time. Please solve this.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
