make sure you have the Ps2 network adapter on your PS2. After that just simply connect and Ethernet cable to the back of the adapter. The other end of the cable goes to your router of course. Turn on router make sure you have a connection on your computer.( e.g. internet works) Then turn on your ps2, put in a game with online capabilities. Go to the online section of the game and create your account. And there you go, you should be connected. Keep in mind some ps2 online might not work they might of taken the servers done since PS3 is now primarily used online.
yes you have a bad laser pick up censor . now you can try to clean the laser by open the unit or buy the laser (pick up censor) and replace i have fix many of this unit and by cleaning never work tha price on the part $50 to take it to a repair shop may be to fix it $90
Depends on what you want. Note that modifying your PS2 in any way voids your warranty. Original PS2's I'm not so sure about. It involves opening the console, though, and I'm sure you can find a video on youtube if you look for it. But since you can't do any modification that won't involve a modchip, you'd better be prepared to solder a chip on there.
Slim PS2's you have a better variety of options. Tissue/Tape mod which blocks two censors and the disc brake, allowing you to use the Swap Trick or get good use out of a Swap Disc.
If you get a swaptool, or make one, you can do this on both the original PS2 and the slimline PS2.
Look up Free_MCBoot, and have an empty memory card ready. Either use the swap trick or use Swap Magic to install the memory card exploit. It'll contain ESR, which allows you to play burned games.
But there will be no support for your piracy, either. Not from the makers of Free_MCBoot, or the modchip makers, or even myself.
The PS2 Works fine right correct?? If it does and you want to fix the Laser do the following :
Step 1 Turn off the PS2 if on.
Step 2 make the PS2 lie down on its back where the PS2 logo is not seen.
Step 3 Take off the Rubber Squares which are located from all 4 corners and take out the screws using a screw driver.
Step 4 Take off the lid of the PS2 after the screws are taken out.
Step 5 near the light of the PS2 were it shows the Green and blue light is a box where the PS2 disc runs.
Step 6 screw the top of the box and you should see a disc if not taken out and underneath the disc is the lens use alcohol and gently wipe the lens with a Q-Tip after doing so put the lid out of box back on and open the disc drive and put a game in it should work or just get a new PS2 Slim.
You should buy a replacement dvd drive for the ps2 , for about 25.00 USD on ebay, it is easy to install considering you already have taken apart the ps2
