One valve on the unit is cold, the other valve is warm. Lifted and released the leverhandle on the temperature pressure relief valve after problem started. Valve operates freely and water flows through discharge line. Manual switch was turned on. I turned the breaker switch to OFF and then back ON again. Unit has power Thermostat setting has not been changed or touched Unit is quiet - no noise or rattling Water shut off valve to unit has a little hard water build up on exterior of valve
1) Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#no
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
2) One pipe on top of heater is warm??? >> breaker is ON >>> this indicates that electric water heater has hot water.
When you opened the TP valve, did hot water come out???
3) Feb 2013 >> add a comment.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Greetings. Our Rheem water heater was installed in
Check temperature probe for thermostat make sure its has contact with tank
SOURCE: Please help me to download an instruction manual
http://www.greatergoods.com/store/energy-savers/tankless-water-heaters/rheem-rtg-74-dvn-natural-gas-tankless-water-heater/prod_386.html
manual above.
I professionally recommend that you get a Plumber/Gasfitter, to check this over, as this isn't usual, and I wonder if there are not "Other" problems too... with anything that uses Gas one has a responsibility to the entire family to have it professionally checked over, in my humble view..
