I do not have a "folder options" folder under control panel and under "tools" there is not a folder options choice. How do I set up folders to show hidden files/folders
Go to controal panal in start then folder options then the view tab
You will have a option to view all hiden folders xp by default will have this turned off Thanx for using Fixya
sorry i did not read your post propapley i will find you a solution
try this LINK this is what it is saying...
open run in satrt type regedit
Select HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer In the NofolderOptions, right click on the file and select “Modify
Put the value as 0 and click on « OK » to reactivate Folder Options
Close the registry and restart your computer to save all settings
THEAR IS A MORE SIMPLER OPTION AT THE BOTTOM OF THE LINK WICH MAY BE BETTER FOR YOU
1.
Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Click Appearance and Themes, and then click Folder Options.
2.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
For Windows Vista and 7:
1. Open Folder Options by clicking the Start button , clicking Control Panel, clickingAppearance and Personalization, and then clicking Folder Options.
2. Click the View tab.
3. Under Advanced settings, click Show hidden files and folders, and then click OK.
My problem is that I don't have a "folder options" folder under control panel.
