It won't turn on so I think I need to repair it using the firmware manager
SOURCE: I need serial # for a Philips Gogear SA177/00
sf000532001532 it's mine but i cannot charge it anymore. so i think you can use it!
SOURCE: Does not turn on properly
Firmware manager should solve this problem.
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
SOURCE: gogear SA5125
www.philips.com/support
enter country
enter model #
click on model #
click on software & drivers
click on firmware upgrade - software
or, just open the Philips Device Manager and click on "Update"
SOURCE: It wont work
goto philips.com then under support and elctronics find your model and download the repair utility and run it on your mp3 player try that first you can also put it into recovery mode by holding the volume up button while you connect it to the pc
If you need any further help, please email us back so that we can continue to work on a solution.
