I downloaded the latest version of the firmware from samsung, I am trying to loaded onto the dvr. I click "upgrade" but it does not finish the upgrade process. I have used a USB and a dvd, neither has worked. Help!
SOURCE: how to download the latest firmware from version 1.27 to 1.68
Should be no probelm w/ XP/Vista. http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player&typecode=8&subtype=MP3+Flash&cmssubtypecode=801&model=YP-T9JAB/XAA&filetype=FM&language=
SOURCE: Upgrading to WM6 from WM5 Doesn't work.
Are you using windows vista on your comp? If yes then i am sorry you cannot install it through vista(its not compatible)
SOURCE: USB firmware upgrade for bd-p1500
Do you use a Mac? I had this same trouble. I use a Apple computer, Mac OS X. The USB flash card I was using had been formatted for the MAC OS. I just used the disk utility to reformat the flash card for MS DOS. Then it worked ok.
SOURCE: Upgrade PC DVD player to read all DVD's?
Without knowing your make/model of camcorder I'm just giving you some basic things to check. Q,E,F,T,B MODEL?? Go to the Samsung/us/support website, enter your exact model number(i.e. sd-616Q or whatever). When you choose your model, a selection of manuals will appear. Look nearer to the top of the page--there will be some firmware updates. Check the date/version listed on your unit. if it's older than that given on the site, upgrade. http://www.samsung.com/us/support/detail/supportPrdDetail.do
SOURCE: won't load blue ray disc
The Laser Pickup Assembly is defective, to play blue ray it needs higher precision and velocity to produce the higher resolution, it is not cost effective for repair.
