the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
The red light is indicating the set has shut down for a specific reason. You can dtermine the reason by going to the sets front panel and pressing the menu button and the device/input button both in together and hold for 6 seconds. The light will switch and begin to blink a series of blinks( First number) and pause briefly then blink another number of blinks (second number) then it will repeat that same two digit blink code. Let me know the code and I will let you know what happened to shut the set down. Respond to this same post for assistance.
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
You have the dreadful blinking red light of death. Long story short the system is broken due to overheating and heat damage to the motherboard and you have a few options:
send the system to sony and receive a refurbished system for $150.
find a local to do it for much cheaper
watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult.
buy a new ps3.
I hope I have helped and feel free to ask me any questions and let me know how it goes.
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
hi.. It's in standby mode. Do a reset and see what happens While holding down the reset button on the remote Press the power button on the tv (The tv will turn itself off the back on) Now release the reset button
It sounds like the lamp needs replaced....
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link. http://servicemanuals.vstore.ca/
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
