Question about Dell Inspiron 8600 Notebook
Force shut down doesn't work
My notebook stops in the middle of starting up. the force shut down button doesn't work. what should i do
  • Fons Op de Macks Feb 24, 2013
    thank you tony and david! got it started again.
    Master:
  • 796 Answers
Pullout battery and powercord
Posted on Feb 24, 2013
6ya staff
SOURCE:
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Dell latitude D600 I was running without a battery when there was a brief power outage. The laptop shut down, and will not restart. It appears to start, but screen never comes on, and after about 30...
Try flexing the whole bottom assembly. that is with the laptop open put your knee in the middle and grab the unit with one hand on the corner closest to you and the other near the screen and put enough pressure to "flex " the mobo right after you push the start button if it doesn't start try it the other way... this has been working for my grandsons d600 for 6 months. i tried a new switch board because the guy that sold me the mobo said the plug for that is known to crack and that didn't fix it. good luck ps you will know it has worked when the 3 lock lights go out and the power light stays on.
Oct 01, 2011 | Dell Latitude D600 Notebook
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
My Wireless Acer Aspire One Notebook is always on. It doesn't want to turn off.
Force shut-down it by holding the power button for a few seconds.
After force shutdown, turn it on again and try to shut it down the normal way again.
Update me what will happen. =)
May 26, 2011 | Computers & Internet
Caps lock led not working
Sometimes electrical components needs to have all power sources removed and reintroduced to work properly. Try performing a hard reset first, if it doesn't work then try updating your BIOS. If neither works...It's pretty much dead and not worth fixing.
To Perform A Hard Reset
  • Shut down the computer by going to the Start menu and selecting shut down. (If you have no display, hold the power button down for 5 seconds)
  • Disconnect the AC Adapter from the notebook.
  • Remove the battery from the bottom of the notebook. There will be a switch/button to eject the battery.
  • Wait at least 1 minute with all power sources disconnected.
  • Re-insert the battery and reconnect the AC Adapter and then attempt to power on the computer.
May 22, 2011 | Computers & Internet
My screen doesn't work, it is sleeping. What can I do ? After I took a rest my screen dit nothing. Whatever I trie, it doesn.t light up.
Try restarting your computer, If it happens again, try to find a pattern in the problem. If you can't restart, hold down the power button for a few seconds to do a forced shutdown.
May 12, 2011 | Acer Aspire One PC Notebook
I have a OM22 directvent type 53r2, in the middle of night we thought it was out of oil & had the oil filed and now it will not re start, the red start light does not come on.
Does the heater have a code displayed? Are any other lights lit on the display? If not you may have a blown fuse. Have turned the power button off and back on? After the heater shuts itself down you have to turn the power button off and back on to get it to do anything. If this doesn\'t help, let me know and give me some more details and I can help you out.
Niten\'s Heater Service on Facebook
Jan 18, 2011 | Toyotomi Heating & Cooling
Dell Inspiron 8600 Notebook Logo
Ekse
Clive
Clive
Alun Cox
