Brads jam
SOURCE: need a manual for craftsman 18 ga comb
go to sears.com where all of these manuals are found in downloadable form.
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
SOURCE: when I pull the trigger, the nailer just goes
The first thing that comes to mind is they are not being oiled properly. Follow the directions for the number of drops of air tool oil to put in daily. If they have been run dry, this makes quick work of the Orings and requires rebuilding the nailer with new Orings.
The second thing is if contamination has gotten into the cylinder bottom thaat can happen if a jam has ever occured.
Dis-assemble the nailer and inspect for these conditions.
SOURCE: my Makita AF 503 18 guage brad nailer leaks air
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
