Trackball doesn't work if you have not selected the sensitivity.
To select the sensitivity, kindly follow the steps:
1. Select menu.
2. Select option.
3. Select screen/key board.
4. Scroll down to find horizontal and verticle
5. Select horizontal-100 and verticle-100.
you can unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide AT&T Blackberry curve 8310 Unlock Code. Buy your unlock code from third party. i hope this information is help you :)Good Luck
If you would like to erase everything from the 8310 and set everything back to factory defualts: First Remove your memory card, if you have one and then:
Click Options, Advanced Options, Security, General Settings, Wipe Handheld. It should prompt you to actually type in the word "blackberry" and then will erase everything from the phone and set everything back to factory defaults. You will need to activate the phone again through your carrier if you would like to continue using it. Hope this helps!
you can unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8310 Unlock Code. Buy your unlock code from third party. i hope this information is help you :)Good Luck
You phone could just need a simple reset if the problem is based upon the software. To do that click the link below to download the Blackberry Desktop Manager and the Blackberry Device Software for your Curve and run the app loader to reset your device https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
From the Home Screen you go to Options-Security Options-General Settings and then you press the Blackberry button, to the left of the Trackball, and choose wipe handheld, when the process is complete your phone will be reset to factory conditions.
