The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
