SOURCE: DRYER SQUEAKS REALLY BAD UNTIL WARMED UP
I took apart the dryer, cleaned and greased the bearing that had no grease left at all(therefore I assumed no easy movement) and it worked.
SOURCE: frigidaire dryer model # FDEB34RGS2 Squeaking
The belts rarely squeal in a dryer and don't get wet, never need cleaned. What you describe sounds like possibly worn out drum slides on the front of the drum housing. Maybe even worn out felt seals. StanStihl has a good point about the idler pulley and drum rollers might need a drop of oil on their bearings. Just a drop or two though, too much and lint can build up on them.
SOURCE: i have frigidaire dryer model #FER341AC0. It is
start at the back its probably a sqeaky belt take back panel off and u should be able to access it if not u might have to dig a lil deeper no big deal
SOURCE: squeaking noise frigidaire electric dryer model #
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
SOURCE: loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
