Hi im josh in cebu phils. may i help? Friend your problem focusses on to hardware. first try to check your video card clean or change then after try to use the monitor.if it still appears the same. 2nd try to use your monitor in other pc.if still appears. the problem is your monitor. if you knew somebody around that could fix tv or appliances let him see your monitor.there maybe one of the capacitor in the monitor that is damage or burn out.let him change it. so that it will work again in condition. good luck.
