Is the drive module located inside the gas tank on the 2002 ford explorer
SOURCE: where is the inline fuse for the alternator on a 2002 ford explor
I see two or three,the schematic shows two in series coming of the wire from the battery junction box to the back of the alternator and a third coming off the second wire,it's a tough call because schematics even factory schematics aren't always right but either way follow the wiring from the back of the alternator,and you should find them.
SOURCE: 2002 Ford Explorer passenger power window problem
Check the fuse panel first, after that check your fuse relays under the hood, if not then it might be a wiring problem.
SOURCE: Can not fill 2002 Ford Explorer with gasoline.
Did you check the vent tube alongside the filler neck? If it is pinched or blocked with something, just what you describe will happen. The air in the tank needs some way to escape to make room for the gas, and it should be through the vent tube. If it's bent, pinched, blocked, you will have a hard time pumping gas in.
SOURCE: fuel pump location 1988 ford econoline
Theres 2 pumps one in the tank, lift pump, and one in the chassis rail under the driver side. The one in the tank is cheap, the one in the rail is not. The one in the tank only produces low pressure to prime the main pump and if it is broken, may not cause that much of an issue except when starting. the one in the rail is a no-start if it fails. The idea is that the rail pump can supply high pressure for the injectors, so a fuel pressure test at the injector rail will determine which pump is playing up. Hope that helps Tim
where is fuel drive module located on a 2002 for explorer? Is it located inside the fuel tank?
