If you are using xp click on start , then control panel, then printers and fax, double click and a small window will open showing all of your print jobs. Click on the farthest left item (on mine it says printers) then it comes with an option to cancel all print jobs, click that. I hope this helps. If that first item does not show it click on all of the options at the top till you find the one that says cancel all print jobs.
SOURCE: Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
SOURCE: my brother mfc 420cn printer won't print
i reset the printer to the original factory settings, and now it works. thanks for your concern and help, richard
SOURCE: brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
SOURCE: Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Perform reconnection inspections on the printer. Attempt to printer documents. The computer should diagnose the condostion either as missing programs or malalligned printer ink or paper or compartments not closed appropiately.
click on the windows logo on the bottom left of your screen. go to devices and printers on the right side of the window that opens. go to your printer and rt click on it. one of the selections in the window that opens is cancel documents. do that.
