Follow the wires from the sensor to the control board and check the ohms there. It should be around 1050-1100 ohms, if the oven is at room temperature. If it is close to the correct ohms replace the control board. Probably a stuck relay on it.Here is the board to order. All parts come with a 365 day, any part, any reason return policy.
SOURCE: I got a F2 error
F2 error code oven too hot, 1. replace relay board (if present)
2. or oven temperature sensor.
SOURCE: Bottom heating element in oven is not working - broiler works
top element don:t heat up on bake
SOURCE: My oven heating element doesn't get red and the
I removed the heating element and checked it with an ohmeter, which showed the element had shorted out. I've purchased another element on line.
