I have a onkyo av receiver with speaker wire inputs for the subwoofer(no rca input).I have a mono cable subwoofer.Anyway I can connect the two so it will work?
You need a RCA sub-woofer cable (analog mono) to connect between the receiver's sub-woofer Pre Out and the sub-woofer. This cable has a single RCA plug at each end of the cable. The cable is somewhat thicker than some audio RCA cables. You can use any RCA cable temporarily.
You simply connect a RCA type line cable from the subs line input to the dedicated socket on the back of the Onkyo.
When you run speaker set up it will set the subwoofer up.
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
Connect the AV receiver's sub out to Source 1 - white RCA phono.
Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
Set the source routing: input 1 goes to output 1 and 2
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input. You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT). Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work. Don't connect anything to the speaker output on the sub, you don't need that.
Hi, Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK. Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required.
Does the subwoofer require mains power? From your description, I'm guessing it doesn't.
If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips.
If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
