I need step by step directions on how to transfer pictures from my internal memory to a camera SD card.
Use the Copy command in the playback menu. Full step-by-step instructions are in the "[Copy]" section of the manual (page 170 in my copy). If you need a manual you may download a copy here.
SOURCE: how do i transfer pictures from a Panasonic DMC-ZS8 to my laptop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
