Question about KitchenAid Dishwashers
I have the same green clean light flashing problem but with model KUDE40FXW, which has the two control panels. I've tried the Sani-Rinse, Heated, Sani-RInse, Heated sequence and nothing happens.
  • cn25
    cn25 Feb 27, 2013
    Thanks Rick Ead,
  • cn25
    cn25 Feb 27, 2013
    Thanks Rick Ead, I forgot to mention that my model does not have the engery saver button that's why I used the Heated button. I've tried holding the cancel button for 10 seconds and nothing happens, and I had the breaker off for 3 days. The green light blinks 4 times.
  • 64 Answers
Sounds like a heating problem you might have to change the controls and heater
Posted on Sep 14, 2017
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 102 Answers
SOURCE: "Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Posted on Apr 01, 2009
Dwayne Hoo-Fong
  • 403 Answers
SOURCE: The control panel start/resume button is NOT
Sounds like you may need to replace the user interface (control panel)
Posted on Feb 03, 2011
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 24, 2009 | Whirlpool Dishwashers
Lights flashing on clean. Program does not take.
Jan 07, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Green clean light flashing dishwasher
Nov 22, 2007 | Dishwashers
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
