Universal remote code for diamond vision dvdv809-03
0047,0082,0039,0653. Check these codes. If you wish to get more codes, check this link.
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
SOURCE: Sanyo tv,RCA universal remote,Diamond Vision player--compatible?
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
SOURCE: Diamond Vision TV Code
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Diamond Vision TV/DVD combos in the One For All URC-3021 Code List.
But
don't
give up; many manufacturer's re-use others' control codes. Therefore,
I recommend using the One For All URC-3021 Code
Search feature to find the
compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
Entry
Search
One For All URC-3021 Reassign
Key
