Question about Sharp XG-C55X Multimedia Projector
Sharp xr-10x projector will start warming up then shut off
6ya staff
SOURCE:
johnrichard
John Schloot
  • 9 Answers
SOURCE: SHARP XR-10X PROJECTOR LAMP
Lamps are easily replaced by the user. Get a new one and pull out your instruction book to replace. Make sure you clean your air filter regularly to give longer lamp life. There is no way for you to "fix" the lamp module without replacement.
John
Posted on Jan 08, 2008
Anonymous
  • 3 Answers
SOURCE: sharp xr 10x
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Posted on Sep 04, 2008
projdoc
jasbo
  • 2239 Answers
SOURCE: sharp xr-10x projector wont turn
if there are no leds lit on the top, then probably the bimetal circuit breaker tripped. you have to take the top off to get to it. it's located on the front of the lamp housing. press the red button. if it still doesn't turn on, it's the power supply.
Posted on Jun 10, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Projector shuts off sporadically
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
Posted on Aug 03, 2009
Anonymous
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
I have tried to reset the thermal switch on my sharp xr 10x, but the button has no resistance to it. Does that mean it is broken? Can I get a new one?
You should be able to get a new one from SHARP.
Does pressing in the button allow the machine to start up.
If not then the other overtemperature switches may have activated also.
The fuse may also be suspect
Feb 26, 2011 | Sharp XR-10X Multimedia Projector
Just replaced bulb when cold it has trouble lighting.
it's not the lamp, it's the ballast. when it's fully discharged, it needs too much power to start. once it has the caps charged (when it's been running and warm), it'll start right away. it sounds as if the capacitors on the ballast are drying up. best to replace the ballast. after you do, make sure the projector is free of dust and dirt. excessive dust will cause premature power and lamp failure due to lack of cool down.
Jul 07, 2009 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
May 31, 2008 | Sharp XR-10X Multimedia Projector
Sharp xr 10x
Apr 26, 2008 | Sharp XR-10X Multimedia Projector
Sharp XG-C55X Multimedia Projector Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
