I've tried multiple cables...I know the cable is good and the TV input I'm using is good. I've seen suggestions to use the 'realtek' audio driver - I don't have that on my model, only the Conexant (I'm running Windows 7 Home Premium). Any ideas?
SOURCE: asus f5r audio
Hi there.
You should be able to download and install your drivers from the Asus website here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Product: Notebook
Series: F5 Series
Model: F5R
Then a pop-up window will appear asking for your Operating System, just select WinXP.
4th on the list are the audio downloads. If you click on the + sign, you'll see that there are 3 downloads. Download and install each one in turn.
Hope that helps.
Tim
SOURCE: can not install sound card on Asus F5R
alrighty, check your bois see if your audio device is disabled, also check in device manager if theres any multimeda devices that have no drivers, then go to sounds and audio devices in controll panel and select the device and theme for your pc some times Windows has a dedede moments hope this helped ^-^
SOURCE: Built-in webcam in ASUS G50vt
happend to me too..hahaha!! i got it when i upgraded to windows 7 .. 2 fixes that i tried and worked with .... 1:) you can downgrade back with your restore cd install everything ... then upgrade to windows 7 .. for sum reason it worked.... or 2:) you can download MANYCAM .. a free app that lets you play with yer webcam ... add graphics and stuff... and flip the video ... *wink wink.. heheh. hope it helps
SOURCE: I just bought ASUS K61IC-x3, where is preloaded
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
SOURCE: i have an asus u52f
Get an hdmi cable and connect it between the laptop and the tv. Then, change input, or source on the tv until you see the laptop on the tv. The laptop should automatically recognize the tv and connect. That's about it. Let me know if you have any difficulties.
Regards,
Joe
