Make sure u have inserted the Batteries matching the Polarity.............
If Stil it doesnt work..............Try using Rechargeable Batteries...............
If still doesnt work call Canon and get teh Camera Replaced................
Possible that the main board has failed the main controller unit. Please check the battery and the VOLTAGE on it by using a good multimeter. If low try and charge or if the charge does not develop then the battery is faulty, It is important that there is enough CURRENT capacity on the battery to switch on. if so test with one before you confirm,
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the arrows to select a language. Press the FUNC/SET button.
If you have the IXY 1000, you can download a manual here (the US version is the SD900). The battery is a Canon proprietary battery, and there is a recharger available from Canon to charge the battery, The specific charger you need will depend on where you live -- different countries have different standard voltages and connector plugs.
