Hi, mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears.
If the
code does reappear, ERR 2 indicates an internal error with the computer
of the warming plate. This may be covered under Kitchenaid's 1 Year
Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
After setting the clock to the correct time . then Press the Set delay then the HR and Min you want the timer to come on. Press the brew strength for your preference. then press the Select Twice to change Led light to Daily Brew. and now it will come on at the selected time.
