Says scanner is warming up then freezes and light starts flashing red
SOURCE: Epson 2400 scanner red light flashing
Normally any new scanner fresh from the factory has a 'lock' which prevents damages due to transportation. Ensure it is unlocked.
S. Mohan
SOURCE: Scanned pictures has thin blue line running through it
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
SOURCE: Need Replacement AC Adapter for Epson V200 Scanner
I have an Epson AC Adapter 220volt/13,5 Volt. Model A391VD As my scanner broke down. Fell from my table.
SOURCE: My epson 3490 photo scanner isn't working theres a
If the start button light is flashing red, it is because of one of the following problems:
After trying these solutions, unplug the scanner to turn it off, then plug it back in.
