Olympus VN-4100PC  Digital Voice Recorder Logo
Posted on Feb 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mensage ERR, not start
Not start
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 04, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
233
Points
Press the DISP/MENU and STOP buttons at the same time for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Randy Morton
Level 2:
Sergeant:
Champion:
  • Olympus Expert 479 Answers
  • Posted on Feb 17, 2009
Randy Morton
Olympus Expert
Level 2:
Sergeant:
Champion:
Answers
479
Questions
0
Helped
118957
Points
522
Replace the batteries then send to repair
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
1helpful
Hola pueden ayudar a resolver un problema en el pos verifone vx 510 me aparece BAD RCT CHIP Y TAMPER me pueden ayudar gracias
Hi usualmente el mensage de BAD RTC es causa de los sensores que la maquina tiene adentro talves esten desalineados la unica forma de reparar este problema es abriendo la maquina y checarla pero al mismo tiempo cuando usted la arma de nuevo le sale el mensage de TAMPER ERROR para eso necesita el software para quitarle ese mensage si necesita mas ayuda contactenos al 775 358 2922
Mensage de error 1770 smart failure hard disk
Replace your hard drive ASAP!
Buy Seagate or Western Digital brand.
They are the most reliable.
1helpful
Tracks/streaml5ra.bun cuando esta instalando tira un mensaje que dice algo de file
cuando instalo need for speed me sale un mensage dise
1,1,TRACKS\STREAML5RA.BUN
Driver of Scanner Gemius not run on the xp vista
Click HERE to got the Genius Support site for your scanner.
3helpful
Sining in to hotmail mensager
In the messenger options / tools there is an option to diagnoise and solve problems, you can use that of you can diasble any firewall you have or open a port on the firewall for messenger
the first solution is recomended
Err err err
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
2helpful
Err Err err err err pau
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
