Microsoft Windows XP Professional for PC Logo
Posted on Feb 15, 2009
CAN ANYBODY TELL ME HOW TO ADD ARABIC LANGUAGE TO WINDOWS XP? TNX
Hello there my name is Shakirah, I need some help with my friends computer, I formatted her computer & I guess I removed the arabic language from it, I want to know how to install it again, it has the arabic prints on the keyboard but it wont write Arabic anymore, please email me with any solution thank you... [email protected]
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
380
Points
Where u want insert
1helpful
3answers
How can i enable arabic font in my pc .i dont have xp cd
You need the XP disc to have it enabled... Alternatively, you can purchase the font from the Microsoft website and to get there, click on this link
Choose the font that you want and then click on the windows xp at the bottom and follow the prompts on how to purchase it.
You can also try the following:
To install another language and keyboard layout in Windows XP, follow these
steps:
  1. In the Windows XP standard Start menu, click Start, and then click
    Control Panel.
    In the Windows XP classic Start menu, click
    Start, click Settings, and then click Control Panel.
  2. Double-click Regional and Language Options.
  3. Click the Languages tab, and then click Details under "Text
    Services and Input Languages".
  4. Click Add under "Installed Services", and then click the language you
    want to add and the keyboard layout you want to use for that language.
  5. To configure the settings for the Language bar, click Language Bar
    under "Preferences".
Here is a free download link in downloading Arabic fonts for your XP
Link
Arabic font nosupport
During a clean WinXP installation, the Arabic fonts are installed as part of what Microsoft calls
Complex Script fonts. (MS documentation.)
To add Arabic font support to WinXP follow these steps.
  1. Download fbarab.zip from this site.
  2. Extract the installation package from fbarab.zip with a decompression utility.
  3. Run fbarab.exe to install the Arabic keyboard layouts.
  4. Restart Windows.
  5. Load the keyboard layouts:
    1. Click on the Start button.
    2. Click on Control Panel.
      • The Control Panel is directly accessible in the standard Start menu but it is inside Settings in the classic Start menu.
    3. Click on "Date, Time, Language and Regional Options."
    4. Select the "Add other languages" task.
      • Or click on "Regional and Language Options" and select the Languages tab.
    5. Check the "Install files for complex script and right-to-left languages" option and click on the Apply button.
    6. Click Yes when you are asked to restart Windows.
    7. Go to "Add other languages" again and click on the Details button.
    8. Click on the Add button.
    9. Select Arabic in the drop-down list of input languages and select Arabic ASDF Eastern or Arabic ASDF Western in the drop-down list of keyboard layouts.
    10. Click OK as many times as you are prompted to and then close "Date, Time, Language and Regional Options."
For MS Office:
  2. Move the pointer over Microsoft Office Tools in Programs and click on Microsoft Office Language Settings.
  3. Select the Enabled Languages tab, check Arabic and click OK.
  4. Leave your preferred language as it is unless you really want to change it and click OK.
  5. Click OK.
I hope that helps.
I need to install or downloads Arabic language into my computer languages so I can type using Arabic keyboard thank you very much sam
Setting Up Arabic in Windows XP
Adding the Language to Windows
The following instructions will help you to set up your keyboard layout for Arabic that matches the DataCal Keyboard Labels.
Step 1. Install Supplemental Language Support
The Arabic language requires that you install Supplemental Language Support before you can set it up in Windows.
  1. Select the Start button in the lower left corner of the Desktop.
  2. Select the Control Panel (or, if you are using the Windows Classic Setting, select Settings > Control Panel).
  3. In the Control Panel, double-click the Regional and Language Options item.
  4. In the Regional and Languages dialog box, click on the Languages tab. In the Supplemental language support section, click on the Install files for complex script and right-to-left languages (including Thai) option (see Figure below).
  5. Click on the Apply button in the lower right corner of the dialog box and then click on the OK button. You may be prompted to insert your Windows install CD into the CD drive.
Step 2. Add Language to Windows
  1. In the Control Panel, double-click the Regional and Language Options item.
  2. In the Regional and Languages dialog box, click on the Languages tab.
1. Click on the Details button in the Text services and input languages section of the Language tab to open the Text Services and Input Languages dialog box.
2. To add a language, click the Add button in the Installed services section to open the Add Input Language dialog box.
3. Click on the arrow to the right of the selector in the Input language selector and scroll to Arabic.
4. The Keyboard Layout/IME should default to the Arabic keyboard layout. If it does not, click on the arrow to the right of the selector in the Keyboard layout/IME selector and scroll to the Arabic keyboard layout. Note that there often are different keyboard layouts for a language. You should select the language and keyboard layout that matches the DataCal Keytop Label.
5. After you select the language and keyboard layout, click on the OK button to close the Add input language dialog box.
6. When you return to the Text services and input languages dialog box, you will see the new input language and keyboard layout included in the Installed Services box.
7. Click on the Apply button to apply the changes to the new layout. Note that each language features a small blue box in the Installed services section with 2 letters that indicates the language. English is designated as EN.
  1. If you do not wish to add any additional languages or layouts, you can click on OK to close the Text services and input languages dialog box. When you return to the Windows Desktop, you can see the language bar in the lower right corner of the Desktop.
  2. To change the language and keyboard layout, click on the two-letter language selector box with the left mouse button to open the language selector menu.
  3. Click on the language that you wish to use in the language selector pop up menu.
The language you select will remain in effect in active Windows application until you select a different language. For example, if you select the Arabic language and keyboard layout in Microsoft Excel and English in Microsoft Word, each application will use that keyboard layout until you exit the application or you select a different language.
Default Keyboard Layout
If you wish to make a particular keyboard layout the default Windows layout (i.e., to be used in all Windows applications), open the Text services and input languages dialog box.
Select the desired keyboard layout to be the default in the Default input language section of the dialog box.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
1helpful
Even after i have installed arabic languages in my pc i cant find arabic when i reach Add option in Details in Languages. i have installed arabic language using xp cd after that when go in Control panel...
u want to change interface or just typing.....
if typing then do this step
control panet,regional setting u know that
in regional setting change english(unitedstate) to arabic(saudiarabia) any country u want
apply this n restart ur pc
if interface
then u need to install multilanguage for xp
follw this link
www.topshareware.com/multilanguage...xp-arabic/downloads/1.html
How To To Install Arabic Language in my computer i dont have the cd of windows xp sp3
borrow any windows XP CD and go into the control panel and use the regional and language settings to add a new language.
MY WINDOWS HASNOT THE ARABIC LANGUAGE
You have to add that as a special Language Pack. I don't know which Windows you have, but if its XP or Vista or Windows 7, you should find "Control Panel" and then "Regional and Language Settings" and then the Languages tab on that box, then add "Install files for other languages" choice somewhere.
Hope this helps! Please rate this.
Dec 08, 2009 • Yahoo Mail
46helpful
4answers
Change windows xp from arabic to english
reinstall service pack 3 with language pack from microsoft.Make sure you back up your registry first.
For xample
If you have XP SP2 in ENG and want to have it iArabic, you will have toDownload SP3 in Arabic (http://www.Microsoft.Com/downloads/details.Aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en change language to desired one then download), change some registry Keys (go to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language Registry Key, and then change the value date for “Default” and“InstallLanguage” Registry value from 0001to 4001) reboot and you'll be able toInstall SP3 in Italian.
  • 0001 = "ar;Arabic"
  • 0401 = "ar-sa;Arabic (Saudi Arabia)"
  • 0801 = "ar-iq;Arabic (Iraq)"
  • 0C01 = "ar-eg;Arabic (Egypt)"
  • 1001 = "ar-ly;Arabic (Libya)"
  • 1401 = "ar-dz;Arabic (Algeria)"
  • 1801 = "ar-ma;Arabic (Morocco)"
  • 1C01 = "ar-tn;Arabic (Tunisia)"
  • 2001 = "ar-om;Arabic (Oman)"
  • 2401 = "ar-ye;Arabic (Yemen)"
  • 2801 = "ar-sy;Arabic (Syria)"
  • 2C01 = "ar-jo;Arabic (Jordan)"
  • 3001 = "ar-lb;Arabic (Lebanon)"
  • 3401 = "ar-kw;Arabic (Kuwait)"
  • 3801 = "ar-ae;Arabic (you.A.E.)"
  • 3C01 = "ar-bh;Arabic (Bahrain)"
  • 4001 = "ar-qa;Arabic (Qatar)"
If noProblems occur, you will have the whole system language changed.
5helpful
I cannot add arabic support to my windows xp. I don't have xp cd
download this file
http://zsigri.tripod.com/fontboard/fbarab.zip
then Extract the zip file with winzip or winrar
then run the exe file
restart windows
then go and try to add Arabic support from control panel -> Language and Regional Options
8helpful
2answers
I want add arabic language in my system but i do not have the windows cd
you can download language packs from microsoft.com downloads
kind regads and please don't forget to rate us
5helpful
4answers
I cant add arabic language to my computer
http://www.microsoft.com/middleeast/arabicdev/Windows/winXP/wPapers.aspx
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
