My kenmore upright freezer fan is running all the time but not freezing and the dail is set on coldest setting. the upright freezer is seven years old
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
its only getting to -10 and needs to be at -20 deg C the fan is working what else do i need to check ??
My 11.4 Cu. Ft upright Kenmore automatic defrost freezer is not cooling. All the food is starting to thaw, and there are puddles of water on the floor. The Freezer is 8 years old! The fan is running. Could the compressor be shot already?
My Kenmore Frost Free Commercial Model#253 is not freezing however the fan is running continuously. The air blowing from the inside top is not cold at all.
Just recently my freezer is set up to the highest temp and it's not freezing anything.
freezer was working fine, then one day food started defrosting and now it won't get below 32 degrees. i'm wondering if the thermostat is bad & how do you check it.It's a 3 year old sears.
My freezer runs all the time and does not get below 40 degrees. The freezer is 10 years old and is a Kenmore but it still looks brand new. There is no dust on the coils and everything looks clean.
If the Freon is low, doesn't that mean that there's a leak in the system, and if so wouldn't all the freon escape at once?
