SOURCE: Stupidly but accidentally left my
Well you can try not to turn it on and let it dry out in a DRY room
But if you turn it on after it was still wet or it was not fully dried ...Then
you have to bring it to a camera repair shop I would call around but
make sure that you do not tell them it was wet because it they may tell you that
there is more problems then just the LCD screen.... So if the board is wet and
there was power turn on there will be clear signs of the residue left from the rain...
You can also call Canon to see if they no of any Camera Shops in your area that will Repair
it or Maybe give you a trade in credit towards a used or new camera,
Thank You
Jayson
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
SOURCE: My PowerShote SD800IS lens will
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
