Record new message
SOURCE: panasonic KX-TGA1018 DECT 6.0 cordless
see manual on website below
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.PDF
SOURCE: How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
