Error 42 will show on the stove at odd times......sometimes at 2:00 am, sometimes every other day. No set pattern. It will flash for a few minutes then stop.\ I read on Fixya that an electrolytic capacitor could be going bad. I would like to have the capacitor in hand when I disassemble the stove so that it can be replaced without delay. Can you describe the type of capacitor. Does it have radial or axial terminals? I imagine that it has radial terminals if it fits on a PC board but I'm not sure. I think the article said that it was a 470uF 35 volt capacitor. I should have no trouble changing it as I am an electronic technician. Thanks, Valgator
SOURCE: My house wires from the electic stove top has 3
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
SOURCE: on a gas bosch stove
unplug the stove and plug it back in. if it keeps ticking, your spark module is going bad
SOURCE: Can't find replacement burner knobs for my
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
SOURCE: bosch gas stove top ignitors
Hi tiggerwillso,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
