System fan error will shut down in 5 seconds ? fan has been replaced still error shuts down before going into BIOS to change settings System defaults were restored before problem ??
SOURCE: HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
SOURCE: my laptop shuts down and attempt to restart but unable to do so.
your bios battery is low but also you need to do a clean xp installation.
SOURCE: my youcam on my hp is too dark and it wont let me restor default
remove the program and driver and reinstall both. one is corrupt most likely. this should fix it. if you have another pc, install fresh on that and see if its ok
SOURCE: HP Pavilion dv6000...startup and shut down...over and over !
there is two screws under the touch bad but they don't look like a screw i don't no the name of it in english but they are somthing that the srew goes into it you must remove them and every thing will be easy to open and replace the motherboard
SOURCE: BIOS hangs at HP logo, can't access bios or boot settings
My compaq presario cq61 360ev gets garbage on screen when its in hibernation/standby position, what is this due to ??? It is in it's warranty time period just got it on the 2nd of January 2010.
