You are right in thinking that the amber light means an erro, but it could be any sort of error in the syntax/printer software, or just a glitch. Also it could mean that the printer top cover is not closed properly, try pressing down firmly on the fronnt of the printer to see if it goes out. It is notunknown for the cover shut sensor to be defective so giving a constant amber light. Further help can be got by contacting www.lancerlabels.co.uk and they will talk you through the problem on the phone - no charge.
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
SOURCE: Hi can you help ? My zebra TLP 2824 printer keeps
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
