Tells me to take tape off cartridge it is already off this is wireless
SOURCE: no printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
SOURCE: alignment problem on lexmark x4650 printer
Try this
Turn off you printer
remove the cartridges
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
SOURCE: when i feed the lexmark x4650 printer with
hello
first check the tray might be the paper is not placed properly, and check the roller pickup of the paper placed upside of the tray, might be the tray is not pushing up the paper to the roler thats why not your printer not picking up paper. try hard reset remove the power cable from the power outlet and at the back of the printer take 5 minutes to plug in back.
inform me then...
thank you
SOURCE: installed new cartridges will not
Try removing the power cord and USB cable from the Back of the printer for a couple of Minutes then plug back in and see if that will help. while unpluged remove cartriges and Paper after plugging in replace cartriges and Paper.
